Having a modded 6.5td in my truck I can say that i wanted hesitate to run one in an expo style rig. I'm considering building a full tube buggy oneday and I'm most likely going to run a 6.5 in it. They're simple, cheap, and reliable when taken cared of. When used in the manner for which they were designed for, it's had to beat the value they give.
Best part is, if a 350 can be swapped in an NA 6.2/6.5 will bolt right up. they weight about the same as a bbc. In the range of 850 lbs fully dressed with turbo.
You're more then welcome to check out my truck. I'm fixing a leaky valve cover right now, but will be up and running this weekend. I know its different being a fullsize, but can give you an idea of how the motors act and stuff.
And definitely no problem with having a detroit under the hood
a little
followed by some
