MrArmyAnt
- Joined
- Dec 29, 2004
- Posts
- 661
- Reaction score
- 0
It's a 77 blazer. Replaced some gauges with aftermarket ones since the stock ones were dead. Motor ran before, a day before, and once out of the trail started again (I think that is an important fact so I know it isn't trail damage.)
Replaced water temp (forgot that it had water behind it, lost some, but it's run on a lot less) and oil pressure. Cut the Tach out, haven't hooked it back up. I know that can't be part of the problem, but that's the only thing that hasn't changed (been removed I mean.)
When I go to start it, the starter just turns and turns. Hit the gas before hand, and during. Thinking I flooded it, I waited a day, tried starting it with no gas, some gas, then a lot of gas, then it smelled like a lot of gas. The only sound I here is that of the starter spinning, never once did I hear a spark plug fire.
Anyone know what's going on?
Also, anyone know how to keep the alternator/water pump belt on better besides making it tighter? I always throw that and coolant steams out all over the place.
