mounting ideas? will this belly pan mounting work?
BranndonC
3/4 ton status
Anaheim, Ca
this look like the best way to mount my belly pan/side plate? the top bolt will be mounted on the flat part and away from rocks, as will the side bolt
the 2 squares are 2x2 1/4 wall square tube welded together to make a strong 2x4, the C looking thing on the right is my frame, the part under it is my skid plate/belly pan, and the piece connecting the skid plate and square tubing is just a side piece
I got it . The piece that touches the rocks will have holes drilled for the bolt to pass through , the socket for removal can pass though it too . the bolt holds the bent part on the backside to the sliders and frame :D
You could make your life a lot easier by building that upper mounting flange a little longer and mounting that bolt from the inside instead.
It will sit flat that way, and won't get "massaged" by rocks.
