TruckNutzDude
As mentioned, shifting the driveline won't change your CG at all, but it will affect the weight bias.....probably in a pretty small way though.
Adding "lightness" might be an easier way to go. Remove all the weight you can up front and you'll probably shift the weight bias in a more meaningful way.
This is the best picture I have showing weight bias (this is before the bed) You can see the t-case hanging down below the frame, the rear output yoke of the t-case is the center point of my rig (roughly the middle of the seats). Like I said, the goal is not to lower my CG it is to change the weight bias and add extra length to the front driveshaft.
I would move the front axle forward more but with my low suspension setup the spring pad would contact the drag link end and pitman arm leaving me with less than 1" of uptravel (I only have 3" of uptravel at the moment). I would have to move the axle more than 6" forward to clear the DLE but then I run into problems with steering since the box 6" or more behind where it should be. I could cut and stretch the frame, moving the axle, steering box and leaf springs while leaving the engine where it is, the drawback with that is obviously cutting the frame.
I do appreciate everyone's opinion, I guess I'm thinking outside the box on this one?
