HELP!! I am installing a 700r4 to a 2000 Vortec 350 for one of my bosses @ work and so far (after extensive searching here and on the web)can not find ANYTHING about the right TV cable to use or even if its doable. Thanks in advance for any help!
Probably not likely to find something, TV cable was long gone by the time of the Vortec 350's as I recall.
http://www.bowtieoverdrives.com/catalog/catalog_inc/viewitem.php?ITEMID=373
There ya go , tv cable system for a newer Vortec system in any vehicle , with a 700r4 .
Is This on an OBD2 2000 truck??
If so unless the ECM is reflashed to ignore the transmission.
You are going to get a bunch of transmission trouble codes. How those codes will affect engine performance I do not know. On electronically controlled trannys there is a bunch of input from the transmission the ecm needs to properly manage the engine.
You will also need something to control torque convertor lock up for the 700R4
Only Vortec TBI I was aware of was in something like panel vans (real rare) and apparently earlier than '96 4.3 liters.
Engine out of 2000 truck, ECM reflashed by Street & Performance, lockup kit also from Street & Performance
