Mr. Clean's dune cruising 71' K5 "Oprah" beams, links, and turbo ls powwwa
Haha. Ive had them for a year just sitting around. Excited to finally use them.
What did you read my mind when I was coming up with plans? Lemme guess so,em kind of method wheel too?
Not sure how this would apply to trailing arms but I remember an article in FourWheeler or something where they talked about solid stock vs. tube when building 4-links and such. It was found that the tube was stronger for all of the applications.
Well...... yes actually I would like some method's. Your spot on :haha:
Kmc cough cough
But after seeing Tom wayes drive 25 miles on just the rim, I'm thinking Trail ready :)
That doesn't sound right.
It is definitely true that solid adds a LOT of weight for a minimal increase in strength over a thick-walled piece of tube. Going to a larger diameter tube adds a lot more strength than trying for strength by using solid, smaller diameter links.
Check out the "Materials" tab in the 4-link or 3-link calculator and you will be able to see it easily... For solid bar, just choose a number that is 1/2 overall diameter of the tube you are working with... (Ex. 2" tube with 1" wall thickness is SOLID rod).
-G
-G
I didnt even think of using that, but i will check that out.
So first on the list is building the 9" and getting that done and ready. I habe a tab zone back bome truss on the way and also a disc conversion kit. Now im planning on upgrading axle shafts to Currie 35 spline shafts( you can get them in chevy 6 lug), thats one of the reasons im going with them. Now im looking to be locked in the rear my dilema is spend extra dough and get a locker or just get a spool? Spools are in the $100 range where as lockers are 300-500 name brand depending. I dont plan on driving all that much on the road. Mainly from camp ground to dunes other then that it would probally be lucky to see 1000 road miles a year. Im not worried about tire wear. My only concern does a spool give any wierd driving characteristics on pavement to be worried about say doing 55mph down a normal country road. I have never driven anything with a spool in it
No the only weird thing imho a spool does is a low speeds normally where you would coast in something you have to give is some throttle, sometimes the steering isn't as light like with a locker but I think.. A spool is much more predictable than any locker..
Just get the spool for what you are doing. I have a spool in my regal and drive it on the road, its just hard on tires. My friend drives his Jeep with a spool in the back too.
Is it DD type parts, no. Can you drive it on the road, yes. Just be careful in the rain.
-G
Maybe it was just about weight vs strength for a given diameter. Sorry for any confusion, happy to be corrected.:thumb:
