MS resivoir leaking
obijuan
San Antonio TX
i just noticed ive developed a master cylinder leak, after two days its saturated the master and booster, fenderwell, and that wierd ball thing in the corner. it looks like its coming from where the resi sits on the mater cylinder, an o-ring maybe?
- so i figure should i upgrade to the disc/disc master from the p30 or whatever. i am going 1 ton with rear discs anyways, but i dont have any of that actually on the truck right now.
- stock parts store replacement and keep the vacuum brakes.
- OR just thought about this, go hydroboost but what all does it take to install hydroboost? never even looked it up. i seen a set up from a cucv in the classifieds here.
in the long run and currently as a double duty daily driver and weekend wheeler, whats my best alternative here?
I swapped out to hydroboost. It's just what I needed, along with the disc brakes, to stop the big tires. I found a complete donor rig, which made it simple to install. You'll need everything from the pedels to the pump.
