Blazeboi1
Registered Member
I have an ignition problem guys. I have had 3 different MSD boxes all of them are 6ALs and the ignition shuts off. It's not a specific amount of time the engine runs before it shuts off but I lose power output from the box. My battery wires are ran straight to the battery and it's a yellow top optima with marine grade terminals on the top. I have continuity to the box from the battery. I was running my switched 12v source off of the original battery terminal to the dist(big white wire with the plastic cover). I have since taken the switched 12v source to the fuse panel thinking maybe I was losing power. I have ZERO problems with my MSD dist. hooked up in the factory configuration. As soon as I take out the ignition module and hook my green/violet connections up it will crank and run but then it shuts off. I've been through 3 different boxes, taken the tach out of the equation and ran redundant wires to all locations to no avail. I'm losing my f-ing mind! PLEASE HELP!!!! Vehicle is a 1979 K5 small block.
and my teacher's words ring in my head mocking me.
