MSD, Atomic EFI
I like it !!
seems super easy to install and setup....
I know from personal experience that every piece of MSD equipment I have ever purchased has performed exactly as it was supposed to.
lot to be said for a company that produces consistently proven equipment. :waytogo:
There is a reason everyone in racing runs their stuff:waytogo:
It looks cool but I'd be weiry of a pulse width fuel pump system. It reminds me of mechanical fuel pumps which are barely adiquate for carbs. The beauty of a return system is constant cool fuel at consistant pressure. The video says that fuel temp can increase up to 50* in a return system, but the warm fuel returns to the cool tank which is far from any heat sources and stays cool.
I like the timing control aspect but you still have to set the timing manually with the handheld controller so what's the difference than the standard mechanical and vacuum advance? :dunno:
I'll stick with my FAST kit, its pretty awsome :bow:
what problems do you have with mechanical pumps for carbs??
Most of my stuff I run a mechanical on.
I run a Carter on my Vette, it feeds the 327 fine up to 6800rpm with a 5/16 fuel line.
I run a Holley 130gph on the Maiden and it does fine also.
