How about a buggy update? It's torn down to a bare chassis right now for welding, I pulled the shocks and unbolted the links from the chassis and rolled the axles out of the way. I'm working on welding everything I can reach as is, then I'll roll it over and get the rest. While I'm at it, I'm taking care of a few welds that I'm not proud of. I walked around the chassis with a paint marker high lighting areas that need help, might as well be honest with myself, right? I want to be proud of every aspect of this car when I'm done.
Before I tore it the rest of the way apart, I got the steering all sorted out. Not sure what the final angle is yet but its north of 45 degrees. I'm going to end up running the tie rods in single shear on top of the high steer arm with 3/4" hardware, all the angles work best there. To make it happen I had to move the lower links in almost an inch, shave down the steering stops and play with the tie rod and cylinder location. The tires barely touch the links at full lock, which will be fine. While I was on the front axle, I had to do something about the lower shock mounts. They just weren't me. So I whipped up a new set, they even match the uppers, speed holes and such. Oh yeah, I got the shock reservoirs mounted too, might have to move the fronts to change the angle of the hose. I'd rather cut metal than fiberglass. And yes, the cooler is an integral part of the design of the car.
We're working on buying a house right now, it comes with a 2 car garage and a small shop on 2.5 acres. I want this thing welded and painted by the time we move in June. Moving is going to set the build back a while so I'm hitting it hard before that happens. I'd kinda like to have all the drivetrain back in by then, we'll see how it goes. If anyone wants to swing by and help, that would be great.
