My 1st tow rig
mudhound72
Oshkosh, WI
I just picked up a 73 Burb 3/4 ton 2x4 with 1 ton rear springs.
The body is in decent shape with some rust that needs repair the rear gate window and latch even works :D
The coolest part is that it has a 500 Cadlic and a th400
Drove it 40 mi home runs good needs a tune up and some other minor repair before being reddy for tow duty.
Some rust eh? Sweet truck none-the-less. I wonder how that caddy will perform towing? My girlfriend's mom said back in the 60s it was all the rage to tow horse trailers with caddies so I guess they get the job done.
Depending on the year and condition the motor is in, that sucker will hang with the newer stock diesels. Nothing says grunt like a 500ci caddy:pimp:
Nice score for sure.
If I didn't buy my 468, I would have gotten a Cadilac Big Block. Tons of torque in that baby!
It is going to be a sweet tow rig when it is done, I few minor things and it is road worthy.
How does a preson ID the motor year to get stuff like tune up parts, what should the timing be set at, and any other tuning tips I might need to know, never worked on one before so I would like a little info before I dive into tuning it up
Some rust? Looks like my old '84 'burb I bought in Minnesota... The floor boards were no longer connected to the sides of the truck after a couple of years, probably wasn't much holding it together before that either. When I scrapped it I scarred the S#!T out of me to see that the fire wall and gravity was all that held the body down to the frame.
I am starting to do some work on it now sence I cleaned out the shop to get it in, the wireing under the dash is a rats nest trying to get all the heater controls to function.
Picked up a new switch for the rear window so I dont need to jump wires, and now the rear window is stuck :(
Apon closer look at the body it needs more help that I care to deal with patch the holes and screw the rest.
Also the seam at the top is seperating the roof from the body:1zhelp:
