G
goldwing2000
Guest
Correct on all counts.
blackblazer717 said:14bff will bolt right up to the 1/2 ton spring pack as long as you get the 14b from a 3/4 ton not a 1 ton because the purches will be in the wrong spot on 1ton
LUKE
stockk5 said:What kinda rear bumper is that? sweet work
i am not positive but after i unbolted the 10bolt axle, i was able to drag it out from underneath the blazer with not alot of problems. but when i tried to drag the 14bff a few inches, i felt one of my @uts drop about a footBL1TZKRIEG said:how much more does the 14b weigh compared to the 10b?
.resurrected_jimmy said:14 FF weighs in around 500-600 lbs IIRC. When I did my swap I could pick up the 10B front (complete hub to hub) but couldn't pick up the 14FF
UofA_Blazer said:How do you tell the difference between a 1 ton and 3/4 ton 14b if it's not on the truck?
