my 72 jimmy build
well i got my new bushings and body lift in, also got my gas tank back up with new sending unit and the rubber lines replaced, the hard lines will be in a bit. taking down the tank i f*#@king wasted about 2 gallons, not easy doing by ur self. ended up making the wife come out. :mad:
well i got a start on my hydro clutch conversion, removed header and mech. linkage. mounted the braket from AA. the slave is pretty close to the fork, i need to throw a few more threads on the shaft and i dont have the right size die, problem #1. #2 can anybody tell me wat fitting goes into a clutch master cyl. for a 94 chevy 1 ton. i also got the ss breaded line. need a fitting to the ss line from master
