y5mgisi
1 ton status
So the trim on the blazer is appearntly held on with stiky tape with the exception of one clip on either end. My trim had pealed away from the body taking some paint with it. As a result, rust has started bleeding out from behinde the trim. This is a thread that will contain all my future body work. This is where it will start.
All im trying to do for the time being is fix the bad spots as the whole blazer needs a paint job in the not too distand future. So here's what i am up against,
So i decided it would be best to tape off the affected area so that i wouldnt hurt the sruounding good paint when i sanded.
And then i started sanding. This is what im left with.
At this point what i need to know is how to treat the heavy pits. Can i just use some rust encapsulator or converter?
After i treat the pits, im thinking just some ryoken green and then some high build primer. After that just some approximately color matched color and i should be flying high until i actually paint the whole truck.
Interesting. I'll give a try pulling the tail light out.
