My death wobble issues resolved
Derf00
Abilene, TX
Last fall I started having at times a bad case of dw on my 60. I had run it a little over a year before dw showed up. I read everything I could find on CK5 & PBB, and then looked at several things that are supposed to cause problems. I was unwilling to just throw money at the problem and hope I got lucky.
With or without the dw I was planning on going to the Redneck Ram, so I purchased it a little sooner than planned, but it solved the problem. Yes, this was an expensive band-aid.
In a reply to one of the posts I had made about the dw, Tim of 4x4 Iron made a post about how he had added a 1/4" washer on top of the spring that sits on top of the kingpin bushing, to increase the pre-load on the bushing.
Last night I replace a broken kingpin bushing, spring, and retaining washer. Before replacing the spring, I compaired it to the new one. As you can see, there is quite a difference.
Just out of curiosity, I disconnected the ram, and took a quick trip to a stretch of road that always produced dw. I am happy to report, it is gone.
what is the height of the new spring? about 2 1/4" ? I can't quite make it out in the picture. Glad to hear that solved it.
you are awesome /forums/images/graemlins/grin.gif i remember hearing about springs causing it....and now i know. how much were the springs and where can i get some?? thanx a lot
NITRO
Springs - GM part # 00462799 - $10.86 ea
Retainer- GM part # 00475504 - $ 2.85 ea
Bushing - GM part # 15536433 - $6.00 ea(about)
Results - priceless /forums/images/graemlins/grin.gif
good to know. now i wish i didnt have mine al put back together. guess ill just mearure one spring when i put the x-over on. i replaced EVERYTHING else in the dang thing. dont know why i didnt the springs.
did you post those part numbers in the part numbers post?
Grant
Hey derf00, just thought I would point out you have the same part number listed for the spring and the bushing. Was going to get these numbers to a friend and noticed that.
Randy's Ring and Pinion can sell you a "knuckle kit" also, for something like $80/side. It includes everything above, plus seals and the spindle bearing too IIRC.
-Dan
