Before any of you get all excited to read this, I haven't done much of anything yet. I wanted to start this thread so everyone could get involved in this and learn things as I do. Folkenheath has helped me with back and forth PMs, his build thread is also something you should visit if you're thinking of doing this to your own truck. I figured any further conversation between him and I should be in the open, so it can help others. I hope to keep this all informative and clutter free.
I am looking to order the FAST EZ EFI 30227 kit, but without the fuel pump. I'm not using their supplied pump and asking to exclude it from the kit saves me a little money. I'm still looking to use their fuel line and pressure regulator. I have already purchased a TBI tank with TBI sending unit. The sending unit I bought doesn't come with the fuel pump either, saving me a little money also. I purchased the Walbro 255 pump and have already installed it in the sending unit, easy btw. Now my tank and sending unit are done.
I have some questions to start this off. I will try to get pictures of everything as I go.
* The fittings that come on the sending unit have a flare and O ring. I would consider these good enough for my conversion, since this is a TBI sending unit designed for fuel injection pressures. Does anyone disagree and why?
* My truck is an '85 blazer. It has a vent and return line. The vent is easy but the return line my next concern. Can I just run regular hose like it is now?
* The fuel line on the frame is perfect, being in CA. I don't see needing to replace them, I didn't have any leaks and I don't expect to have any even with higher pressures. The hoses on the passenger side frame rail is another concern. The return side is address in the last question. The pressure side is something I'll need to modify. Should I just cut the ends off, install fittings, flare the lines, and get a short EFI hose made for the 6-8"?
* Should I make the same kind of hose and flare ends for where the sending unit and fuel lines meet? Can I get away with running hose for the return @ the tank?
* The fuel lines on the frame @ the engine are also set up for hoses.
Folkenheath: How does the FAST EFI set up address this area? I'm guessing I'll need to flare these ends also.
That's it for now. Sorry to say...my engine is not even in the truck currently. I just took it out for some changes. I'm still addressing my suspension. The truck isn't in a position to get at the tank stuff, so this thread may take a while, but figured it was still worth starting now.
Folkenheath
http://coloradok5.com/forums/showthread.php?t=281710&page=15
FAST kit
http://atlanticspeed.com/productcart/pc/viewPrd.asp?idproduct=6176&idcategory=172
Walbro 255
http://www.summitracing.com/parts/VPN-GCA758-2
Sending unit
http://shop.advanceautoparts.com/webapp/wcs/stores/servlet/product_Sender;-Includes-Fuel-Sender,-Float-and-Strainer-%28Fuel-Pump-Not-Included%29-Spectra-Premium_18320636-P_2159_R|GRPFUE2AMS_____
TBI tank
http://shop.advanceautoparts.com/webapp/wcs/stores/servlet/product_Fuel-Tank-Spectra-Premium_5322200-P_1296_R|GRPFUE2AMS_____
Folkenheath
FAST kit
Walbro 255
Sending unit
TBI tank
) I'm thinking of running the FAST EFI supplied hose down to the supply line, fitted with the same threaded fittings. The same supplied hose will run from the pressure gauge to the return hard line on the frame. I think I will use a barbed fitting on the line, run about 3" of hose, and clamp it to the OEM hardline. I think this should be plenty good for a return line.
