sled_dog
1 ton status
unless you can view PIDs are you just going to be throwing stuff at it hoping it fixes the problem.
good point. cycle the key, see if it lights up. If it doesn't its required to!Jason4x4 said:may sound dumb, but does the check engine light actually work?
. We recently did this to my buddys aunts Mountainer. Drain out most of the oil, leaving a little under a quart. Start the truck back up, open oil fill, drop in some sand, and a few pebbles
, then rev to about 3500 RPM for a few minutes, until you start hearing some squeaking, clacking, or other strange noises
. Break the oil fill dipstick right above the fill line. Pour two quarts of oil back in, and bring it back to the dealership.
