. I need to get a 203/sm465 adapter to run the doubler. I already have the 56" springs/hangers that I had planned on using on my other blazer build but Ill put them on this instead. Should go together pretty quick I would imagine. No Ill have to make one. Im thinking about a forward tilting hood. Never done one but cant be too hard since the truck is already stripped down this far. I'm sure Ill steal some ideas from the achivesDid it come with a modified hood too?
. Maybe 1/4-1/2" is a lot in the world of rock clearance...I dunno cuz' I've never been
I'm not opposed to getting schooled if you take the time to give me your what for's.
.....helpful as always!!!Yeah its in the garage. It goes under the green blazer. About two months ago I went to wrecking yard to get a set of 56" springs and came home with the blue blazer and the frame in the pic. I couldnt believe someone junked that blazerI see you have two blazer tubs, but one frame? Is there another frame somewhere?
. Worked out perfect because I avoided going rock crawling for about 7-8 years because I didnt want to jack up the green blazer body. Then I said fook it and began the green blazer build for crawlin'. Then found blue blazer already dovetailed front and rear so I shifted gears and started that build. Im gonna start the green blazer build when Im done with the blue one. I plan on a big block build and sticking to sand/mud for that one. Here is a pic of the other frame...
