In the last week:
1) The output shaft of my TH400 broke, requiring a complete tranny rebuild.
2) Water pump went out
3) Rear axle oil seal sprung a massive leak spraying oil all over and ruining my brake shoes
4) Driver's side rear shock mount cracked off at the frame
When will it end?
Any thoughts on fixing #4? The tab on the top of the frame cracked in half. Access for welding up there is non-existent, plus the gas tank is right there. That mount has been nothing but problems for years, always coming loose where it goes through that spot. It probably cracked off because it was rattling around.
When will it end?
