87BrnRsd
Hey...where are you at in North Carolina? I am currently living in Boone right now, but in about a week ill be in greensboro for the summer. I plan on going to uwharrie quite a bit...we should meet up. Actually, me and a couple guys from school here are planning a uwharrie run towards the end of may. Should give me enough time to put on the headers, intake, fix the blown up hub, and get a new driveshaft made.
To answer some of your questions, I personally wouldnt run 35's on a 10 bolt rear. Reason being is that they are semi-floating axles and if you do happen to break an axle shaft, your tire will fall off. Not good if your doing the hillclimb on daniel.
My buddy had a blazer in high school with a rear 10 bolt and 35's. He broke a shaft crossing a small ditch at school and his tire came off down the road when he was going 45. Scary in a lifted truck. The front 10 bolt is full floating (as all fronts are) so if you break a shaft on that one, the tire stays on. I would suggest upgrading to a 14ff rear. They can easily be found for $50-150 dollars in junk yards and you can look for one with lower gears that you will need to make your tranny and engine happy with 35's. The front axle will work. Just having the peace of mind of having a 14ff rear while going up a trail with a hill like daniel makes it worth it. Im running 37's on my 14ff rear and 10 bolt front. Locked at both ends. In the first 15 minutes of wheeling it at dpg i blew up a front hub. I know im living on borrowed time with a 10 bolt front, locked with 37's, but i carry spare shafts and ujoint and the tools to fix them on the trail....so its ok.
You said something about upgrading to a d44 up front. If you have a 10 bolt, dont swap it for a 44. They are both almost identical in strength and parts are cheaper for 10 bolts.
Other than that, i would suggest against a body lift. Worthless in my honest opinion. And you said there was nothing extreme in nc.
Ever heard of a little place in the mountains called Tellico?
Yeah, its extreme. The place i referred to earlier as dpg (devils playground) is near uwharrie and in about 1 total mile of trails, they have obstacle that make uwharrie look sissy. It is private land though, so you have to wait till they open it for a public event. The ck5 crew made a run there about a month back....you can look at the pictures if you want. Under the "regional" forums....click on the southeast region....then scroll down to the post entitled "dpg march 06." Lotta nice rigs there.
And pictures of me breaking my junk.
-Harrison
My buddy had a blazer in high school with a rear 10 bolt and 35's. He broke a shaft crossing a small ditch at school and his tire came off down the road when he was going 45. Scary in a lifted truck. The front 10 bolt is full floating (as all fronts are) so if you break a shaft on that one, the tire stays on. I would suggest upgrading to a 14ff rear. They can easily be found for $50-150 dollars in junk yards and you can look for one with lower gears that you will need to make your tranny and engine happy with 35's. The front axle will work. Just having the peace of mind of having a 14ff rear while going up a trail with a hill like daniel makes it worth it. Im running 37's on my 14ff rear and 10 bolt front. Locked at both ends. In the first 15 minutes of wheeling it at dpg i blew up a front hub. I know im living on borrowed time with a 10 bolt front, locked with 37's, but i carry spare shafts and ujoint and the tools to fix them on the trail....so its ok. You said something about upgrading to a d44 up front. If you have a 10 bolt, dont swap it for a 44. They are both almost identical in strength and parts are cheaper for 10 bolts.
-Harrison
, due to some family money issues. It's not a big deal right now since I won't be driving until September, but sometimes you just gotta help out the family first. I'm definitely going to get another one though, soon.
