My new truss/traction bar
85mudblazin
Austin,TX
Ever since I got the Stak in I have had some CRAZY axle wrap. So I decided to build a truss and tracion bar to control it all.
To build the truss I used some 3"x3/8" flat and cut/bent it to my liking. Then I plated both sides with some 16g sheet.
Heres some pics:
Then made some plate to tie it into the pinion support.
I then started the mick up of the bushings. The bushings are from DIY4X and the tabs are made out of some 3/8" plate.
Heres the actual traction bar I came up with. The twist/slip parts are made out of some 2"x.25"wall DOM then a piece of 1.5"x.25"wall DOM and turned it down for a nice smooth slip. The 1.5" tube goes 12" into each side for more support.
The main bars are made out of 1.75"x.120" HREW with some 1"x.120" Square braces.
It seems to work good, I can jack the whole truck up with the pinion and the springs dont even budge.
I wish I had my steering done so I could go try it out!!
Cool design, nice homebrew execution. I like that square driveshaft too.
Very nice, how do you like the square-tube driveshafts? i've been thinking about making some for my truck
Thanks guys, I love the square driveshafts just have to make sure there is zero bind in them. Takes a little while to get that just right but they work flawless.
broncoman6524 said:
these would work too good onthe street right? (driveshafts) lol sorry kinda noobish question
Nah I wouldnt run one on a dd. They do vibe some. I cant really notice mine but with 4psi tires and a soft suspension I cant really feel much:D I have had my rig up to around 50 mph and its a smooth ride.
