Yup 6.0 Gen IV LY6 or L96 is the current plan in my head. I do sometimes think about a 200k mile 5.3 with a Chinese turbo because that's the cool thing to do now.
Glad you have oil pressure back. Hopefully it stays together!Good news everyone!
The new oil pan with it's baffling and bolt on pump pick up works flawlessly! I took it all the way to redline around a corner and oil pressure just keeps climbing to 75+ psi. At idle warm I'm still at about 25-30 psi. This is also with the 20w50 VR1 oil. Which strangely is now easier to find than conventional 10w40. I guess manufacturers are phasing out that blend?
Oh well I'll stick with 20w50 VR1 until it starts getting cold then I'll switch to 10w30 VR1.
So I changed the spark plugs the other day and I've noticed that it seems down on power and detonates at lower rpm higher load situations. I went with @folkenheath suggestion and installed NGK 6962 or BKR6E gapped at .045". The AC Delco #"5" I took out were definitely worn and had some build up on them. I figured fresh plugs wouldn't be a step backwards in performance. Maybe these plugs are too hot? Is my gap too big? Were the old ones worn out enough that I could run more advance? Is that a thing?
I don't have a box.What is your timing set at? Do you have an MSD box?
What doesn't make sense is you went to a colder plug and now you are getting detonation? Delco has colder plugs with a lower number, NGK has colder plugs with a higher number.
Detonation is definitely not good if that's true. Is it pinging or is the unburnt fuel in the exhaust exploding because of fouled plugs with too large of gap? I would check your timing, I'd set it at 34 with the vacuum can disconnected at 4000 RPM. Then check the timing at other RPMs to see if you need to change the curve, make sure it isn't going higher at higher RPM.
What is your cam duration? Depending on your overlap it can foul plugs easier and a hotter plug may prevent that but may also limit timing and power at max torque, etc.
I'd check timing first, then check plugs and maybe reduce gap(especially if you don't have an ignition box), and if necessary I would change plugs, but only after checking the other two first.
That does look pretty solid
how much will you have to rework the mounts?
The FAST EZ EFI 1.0 does 1 fan. I can have it trigger both relays at the same time and have it run both fans but I worry about the inrush current for my charging system. My current large single fan wired to high speed will dip the voltage and engine stumbles when it kicks on. The voltage recovers once the fan is up to speed though I think I've really pushed a v belt alternator as far as it can go. One dual fan at a time should be much easier to handle.Why do want to run one fan on a manual switch? Can the fast not handle the Voltage drop or amp load of both fans? Or it's just preference?
Second fan is on a relay?
Or what about one of those little controller for the second fan?
I have a 94amp alternator for a mid 80s K30 big block. As far as I knew that was the largest stock one that could be had in a vbelt. I know the aftermarket has bigger options but I like having a lifetime local parts store warranty. It has come in handy multiple times.I'm not familiar with your charging setup however summit sells a replacement 140 amp alternator for V-belts around $100 IIRC. I run the alternator on my truck and a friends truck with twin fans triggered by EFI without any noticeable rpm dip or stumble for that matter. Then again both are big block trucks so they need the extra air movement.
