Some minor updates:
Got the truck out of storage at the end of March only to have 2 snow storms still come. What a screwy winter
It was great to be driving it again but there were some things that needed attention. First the gas gauge stopped working, the rear brakes were groaning, the tcase was leaking, needed a new parking brake cable, a recall on the short throw shifter, and the lower radiator hose started leaking again.
First thing I did was pull the drums and inspect the brakes. They looked fine to me but the passenger side had some slight contamination on the shoes so I changed them out and readjusted both drums. The groaning is gone and the pedal feels a little better but I still get a pronounced clunk from the rear every time I hit the brakes. I deduced that it was the slop in the Detroit Locker causing it. It's annoying but I guess it's the nature of the beast.
Parking brake cable was easy enough so I dove into the tcase which threw some curve balls at me. See my separate thread here:
https://ck5.com/forums/threads/np208-reseal.325564/#post-3631805
I basically split the case, the internals looked good so I cleaned it up, new seals, new rtv, new output bushing, new slip yoke, and new Spicer ujoints.
Onto the gas gauge. After troubleshooting every possible thing it wound up being the sending unit... damn
So I dropped the tank and down comes a crap load of sand imported from Michigan
So I installed a new sending unit modified (again) for my Walbro fuel pump:
I've sent the shifter out for the recall and The lower radiator hose will have to come up with something better.
