My SAS S10
Looks good alan. I think you should leave the body the way it is, it may look funky with stretched front fenders with such a small body.
Good luck
Good luck
Nah Stave, they look pretty normal with the stretched front fenders. Not too much of a difference really...
Okay, haven't seen one so I just threw an idea out there. Thanks:)
rencher2 said:
Why dont you just put the body on an old K-series chassis ?
because K-series frames are JUNK. Everyone builds an S10 body on a K frame, I wanted to be different AND use a better frame. THe S-series frame is boxed all the way back past the crossmember. With 4 square feet of sheet steel I can box it back passed my lower 4 link crossmember. K series frames have little to no straight sections and are all open C with riveted crossmembers. I'd just rather stay away from one from now on. If I every build another older K-Series, I'll build an entirely new frame.
