My shop build
Shop build thread
There are many more options for stove pipe boots on metal buildings than there was since I built my quonset,back in 1992..including these hi-temp silicone boots..stove pipe boot.jpg
Back then all they had were metal mostly,and rubber ones weren't up to handling the temps .
It does not take much for air intrusion to make a big difference..
After I noticed water pooling up in the bottom of the arches where they bolt to a U channel to fasten them to the foundation walls,I decided to drill 1/4" holes ,two close to the bottom each arch and the channel,so water could drain out..
The first winter after that,I noticed it took a lot longer to warm up in there using the wood stove,and it'd cool off a lot quicker,especially if it was windy..
At first I blamed the overhead door,and tried adding furring strips and weather stripping to seal that up better--it helped a lot,but I could still feel a chilly draft if it was windy--I noticed one day a beam of sunlight was shining in thru those holes I had drilled--and placing my hand near them,I could feel a blast of frigid air blowing in.
I added it up..20 arches,with 2 holes each drilled in each one..
40 holes X 1/4" =10" ,so it was equal to having a 10" hole in the walls..(if I did the math right!)...no wonder it was cold!..
I used waterproofing tape to cover the holes up in the winter..made an immediate noticeable difference..
The walk in door bottom has to have a large gap at the bottom due to an uneven slab that tends to heave up a bit in winter--I put a flap made of old inner tubing on the door to help kill the draft that gets under it,but something like conveyor belt would hold up a lot better--right now there isn't any rubber there..
I never thought about adding up all the small holes like that and how big of an impact it would make. My little shop is filled with small holes like that and it is very hard to keep it warm.
I’ll check those boots out too! That may work out great. Thank you
You need to look at it in terms of area of a circle...the equivalent diameter of one large hole to 40 1/4" holes is 1.58 inch diameter. Which doesn't appear to be much, but it doesn't take much to feel the effect of a draft.
I think 10" dia. was calculated from 40 1/4" circles laid out tangentially on a line, which is correct, but the problem needs to account for area.
So I finally got electricity in the shop. I have wired my compressor and 2 outlets so far. I bought a 40 space square d QO box, so I shouldn’t ever run out of room in the box
when i get some more days off I’m going to rent or buy some scaffolding to put up all my shop lights.
i left the romex long, because it is temporary for my compressor. I didn’t want to cut it because I plan to use it later. I haven’t bought the 10/2 mc cable yet...
Well i have a few updates. I got my heater installed and i have started putting up my lights. I have 2 mounted in their permanent position and I have started installing boxes and wiring. Man that shop is going to be bright!i have 14 more to put up
my wood heater is working great! Been enjoying my coffee in the mornings out there and bourbon in the evening.
Yea it’s fairly common. Several of my coworkers got the weld up kit over the bolt up... you save a ton of money on materials. Going weld up almost paid for the labor to erect the building for what i saved in materials. Plus i upsized the beams 2 sizes and still saved $$.
I really don’t like heights and being up there on scaffolding sucks lol. I have to drink a beer or two just to calm down enough not to shake the whole scaffold while I’m up there. Otherwise the whole thing Oscillates while I'm up there
My lift finally is finally here. I drove to fort worth and picked it up. I had to go there anyway and I took the trailer with me... Derek weaver 10k ali certified and best if all it’s black. I’m glad I waited for this color to come in.
got it standing and all bolted together. Maybe tomorrow I will double check it again and make sure it is squared up with the door and bolt it down. Then run my cables. They didn’t include the hydraulic lines somehow they were left out. Got to deal with that Monday.
Finally got the lift working. I still need to install a plug and outlet for the wiring. That way if i need to cut power in an emergency i can yank the cord out of the outlet.
I put my wifes car on it yesterday to do some front end troubleshooting. It was so nice to finally have a lift
Lifts are nice to have.
Please tell me you fixed the wiring to the pump. My OCD hit when I saw the second picture.
Edit.... Never mind. Posted at the same time you did.
