hd44blazer
So I bought this homemade trailer about a month ago and finally cleaned up the backyard enough to roll it back there and get working on it.
The first question I have is should I stay with 2 axles or go with 3? I've found a supplier that has 2 5200lb axles with brakes right around the
same price as 3 3500lb axles also all with brakes, is more better in this case? I've done some searching and seems like a mixed pot of opinions
on this topic. I've got some of my own opinions formed from reading a bit but wanted to here some outside input as well. Thanks guys.
Here's the trailer in question, it'll eventually be for my truck that weighs about 6000lbs loaded up. The main frame is large I-beam and bracing
is a mixture of 1/4" angle and C-channel.
Good catch
