So I have found two green wire near the break boster that are just hanging out. One would assume because there is two wire that it would be just one wire that has broken.
For some reason I dont beleive that to be the case, because they are both going back in the same wire bundle. If they were supposed to be together it would mean that the wire had a big loop in the wire bundle and that seems odd, and the wires dont necessarly line up with each other as one would expect when a wire breaks.
One green wire rings to ground
the other green wire is open.
These wires are in the same wire bundele where the two big red power leads come out by the break boost and go to the power distribution terminals on the fire wall just to the left of the power boost....
Needle in a hay stack.....
Wonder if this could be related to my cruze not working...
If I were smart enough I would show a photo to help explain better but I cant seem to figure out how to attach a photo
