One of the green wires rings out to the AC clutch two prong connector on the green wire side. Not sure what this tells me..... not sure if it is ringing out to that because its a common or not...
one green wire has continuity to ground
One green wire has no continuity to ground
If I hook either one of the green wires to my negative lead on my tester and take the other lead to the positive on the battery they both show 12v
I would have expected both to ring to ground being that they both produced 12v to the positive of the battery
