naked dash
bear76
here
There was a post a while ago which had pictures of the dash support/ removed dash pad, I cant find it. Could somone help please and post these pics.
Thanks.
Got a few of mine if it helps any...
I have a few close ups if you want. Mostly those that show how the cage goes through though.
Rene
I have my parts truck(1989) that is naked let me know what angels you need or area specifically and I will go take pics for you.
I have tons of it apart...
What are you looking for in particular, I could go snap a few pictures.
-Avery
So that's what the radio wiring looked like on mine - before a previous owner chopped the plugs off (because they were apparently too cheap to buy an adapter harness that would allow them to leave the plugs intact).
could anyone snap a pic of the drivers side upper door mount while they have the dash apart? would like to know if id be wasting time taking it off to change the broken mount
OK maybe I'm tired clearify what area you need pic of.
Yeah, I'll try to snap one tomorrow before work, if not then when I get home.
Oh, and as far as the wiring goes it all depends on what the p/o had in it 1985_K5_Silverado, if he was going from the head unit to stand alone amps then to speakers then there was no reason to get a harness, it would be a waste of money.
-Avery
I'd like a shot of around the vin # plate. Thanks for the pics.
I'm on my lunch break right now but I'll try to get them shot after work and posted up.
Mmmm turkey sandwich & BBQ chips!
-Avery
Ok, I wen't out and took the pictures then I came in uploaded them onto the computer then got sidetracked on CK5 for two freakin' hours so now that I remembered what I came on this evening to do here they are...
-Avery
and the last ones, sorry for so many but I got out there and couldn't remember what I was supposed to take a shot of so I just started snapping and hoped what you were looking for was in one of them.
-Avery
Avery4jc said:
cant really see it but from the top pic if you move the camera twards the windshile and point it down into where the mount is that would be perfect, my dad doesn;t believe me there is a 3rd bolt hidden up in there.
If you're hoping to unbolt and remove the dash assembly I'll tell you right now it ain't gonna happen. The whole deal is spot welded to the cowl/windshield frame as well as being bolted on both sides. From memory i don't recall more than two bolts on either end though...
Here is a good shot of the area you're looking for though (with gauge cluster removed)
Rene
