owenst7
thanks. If I replace the drag link now and then lift it in 6 months will I have to replace it again or just adjust it once its lifted?
those part numbers you gave me came up as tie rod ends on oriellys website. I know the drag link looks pretty much like tie rod ends but is that the right numbers?
The morons that operate the system at Oreilley's and Autozone don't know the difference between drag link ends and tie rod ends. A solid-axle K5, K10, K20, and Suburban uses ES2026R, ES2027L, and whatever the adjusting sleeve is for the drag link to connect the steering box to the axle. The tie rod is a tube, ES2234R and ES2233L, and I think another adjusting sleeve for the tie rod to connect the knuckles and keep them pointed in the same direction.
You should educate yourself on crossover steering. There is a ton of threads and information about it on this site. The stock steering geometry is pretty atrocious even for a lifted street-only vehicle. My advice is to avoid spending any money on the stock setup and save your money to piece together a crossover setup, especially if you are going to be modifying the truck and/or wheeling it.
