so its a drag link and I have one on each side ?No. One drag link.
that's a good idea.........Go look at the other side...
if you have the money replace the tierod ends and tthe ends on the draglink at the same time. then get it aligned
will do. where is a good place to find a drag link?
thanks. If I replace the drag link now and then lift it in 6 months will I have to replace it again or just adjust it once its lifted?A parts store.
Moog is the preference for brand usually. ES2026R and ES2027L are the part numbers.
with the lift im looking to get it is going to have a raised steering arm. Looks like i'm gonna be changing the drag link and tie rod ends next weekend.Instead of messing with it to get it apart just pick up a new sleeve too, they were pretty cheap. Most lifts are either a taller steering arm or pitman arm so more than likely you will use the same one.
