im in the market for a good but not over priced aluminum radiator for my 1990 gmc v3500 6.2 diesel . Local parts stores want $450 plus for a stock replacement . I cant see spending that much on a stock replacement , i dont use the oil cooler and have a external trans cooler.
My truck keeps getting pretty hot when i go up hills , the gauge will read right to the bottom of the red and sometimes goes into the red , i have done thermostat , flushed coolent, fan clutch, flushed radiator at home and the radiator im running now came from another parts truck cause mine was leaking. Normal freeway temp seems to run around 200degrees
