Kain
3/4 ton status
small vid (sorry bout the crappy vid) thought i had a bad u-joint took out drive shaft and found this.
how much play should be there? also should the transfer-case output shaft have play in and out if the retaining nut is tight? crap didnt work
You in to fab work, then it has a probability of fitting. Not to forget all the other little things that can go wrong. Does the gear ratio match the front of yours? May need a conversion u joint.
