handloader90
Building!
Hey all,
I have a D60/14BFF. The Dana 60 was already missing the breather tube piece so I tapped the hole for NPT. The 14 bolt had the factory fitting in the breather hole, I drilled it a little bit until it came free and then I tapped that hole for NPT.
I want to close up the diff breather holes on both housings and drill and tap my diff covers (they're both 3/8" thick or so) and run my line/bellow from there.
Now I want to plug weld the holes and wanted to know the best method of doing so. On the 14 bolt I will have to take all the guts out due to the location of the hole on the housing.
*Should I use MIG or stick?
*Should I clamp a piece of aluminum to the bottom of the hole (inside the housing) to control the weld to make sure that it doesn't protrude past the part of the hole in the housing?
*How do I go about heating the housing up and to what temp.?
What about post heat?
With the Dana 60 I might be able to get away with leaving the guts in due to the hole being pretty close to the front/face of the housing.
To my understanding the housing material is different between the two, Dana 60 being cast steel and 14 bolt being cast iron. So pre/post heat wouldn't be needed for the Dana 60?
even then just plug them with pipe plug and sealent.
