need alittle help
stew76
Registered Member
OH-IO
First off I have a 1987 Jimmy w/ 6" lift and 33" tires for now.I just bought a 1975 3/4 ton frame w/ axles (14bff and d44) that I'm planning to swap over. I have ORD extended brake lines w/ 10mm banjos. Can I just buy 79-87 front calipers to fit my brake lines. Also I'm thinking of calling Kert for his 14bff disc brake conversion. Is there anything special I need for that. And also besides the conversion u-joint is there anything I need for this swap.
Thanks,
Bryon
