need backing plates (caliper supports) for 10 bolt 8 lug conversion
I have some 3/4 ton D44 hubs that you can have. I think they are compatible with the 10 bolt. I also have spindles as well but no rotors. Someone is looking at the backing plates now. You can have the stuff for shipping cost. I may even make a trip with the family to Fla soon. Let me know if you are interested.
Jeff
Sweet man...I know i will take the hub from you.. Do i need the spindles to do the conversion??
well if you get a chance go ahead and figure out the cost to ship. Only think is i need them kinda soon. sold my 6 lugs and 8 lugs should be here end of the week and i dont want my car down for too long.
Try fed ex for chepapest shipping. Thanks man!
I will box up the hubs first thing in the morning and get the shipping for you. You may check the and see on the site whether the D44 hubs will go with the 10 Bolt spindles. I will dig up my spindles just in case. It should only take a few days to get to you. I will let you know as soon as I get any more info.
Later,
Jeff
The split for large vs. small bearing spindles is 1976 and older vs. 1977 and newer. All 10 bolts fall into the large bearing catagory, but the D44 you need to check. Since it is a 3/4 ton it is easy to check though, small bearing spindled 3/4 ton's also have the large hex head 6 bolt external lockout hub. Large bearing spindled 3/4 ton's use the small allen head internal lockout hub.
If you end up with the small bearing spindles and hubs you will also need the stub shafts to match since they are a different length than the large bearing version. Other than that any year 3/4 ton backing plates and rotors will work (but I'd recommend new rotors anyway).
Ken,
I need a zip code for shipping rates. Also, my hubs are the later, big bearing type in case you were wondering.
Jeff
Hey sorry, its 32114
kenneth DeRamus
32114
If you wanna save a trip to the store i can go ahead an front you like $30 for the shipping. if its more, LMK, if its less keep the change
please verifiy you paypal address for me to
shipping info is in the pay pal reciept
You might want to take your personal info to PM's. Not good to post it for the world to see sometimes.
