mudhog
THEGAME
ok so i have a 95 s10 blazer. we wear up in the mountains the other day elk hunting in the snow. on the way home the blazer in cruse control started slightly jerking and would also do it off cruse control just at an even throttle maintaining speed. then it got worse and worse and would barely run. just before getting home at a light i would have to hold the brake and hold the rpm at like 2500rpm just to keep it running. ok so what we have done put all new plugs wires cap rotor and also put in a new pressure regulator for the injection system. it then started ran for about 30 seconds and died. when i did get it restarted i had to pump the gas just to get it to start and keep it running. checked fuel pressure and it would prime to 65psi then drop fast. put old pressure regulator in and it started and ran for a day not right but it was drivable. then it got bad again and wouldn't run. i had took the new bad pressure regulator back and got a new one. put that in and again it ran for a few min and now wont start again. this time the pressure gauge when priming will go to 55-58 then slowly build to a little over 60psi. but wont start. also replaced the map sensor and the idle air control and the egr valve. still wont start but if you do happen to get it to start you have to pump it to keep it running
