Slat02
Registered Member
Hello everyone. I am finishing up on swapping out my TBI 350 for a TBI 454 in my K5, and I have run into an issue I have been unable to fix. I am not getting any fuel from my TB. If I poor fuel into the TB, the engine will attempt to start, but other than that, I get nothing. I have checked everything I could think of, and still no results. Here is what I’ve done thus far and what I know to be working. I have checked all fuses and relays that I could find and everything was good. The fuel pump is new and comes on when I turn the ignition. I unscrewed the fuel line after the filter to check fuel flow, and when the ignition was turned on the fuel appeared to flow fine. However, when I undid the lines at the throttle body there was no fuel at all. I blew air through the line and there was no blockage. I checked for power to the injectors and everything seemed fine there as well. My distributor and ignition module are fairly new so I don’t think they are causing my problems. My fuel pump relay is also working properly and my coolant sensor is good. I also went through the engine bay with a light tester and could not find anything not getting power. Here is a little more back ground info on my engine also. It did not come from a TBI equipped truck, but I have managed to swap everything from the 350 to the 454, minus the egr and oil pressure sensor. I had it built to be TBI and computer friendly. I have a high flow TB from R.V. Morris Machine and a custom chip from TBI Chips. Any help would be greatly appreciated as I am at a loss. Thanks in advance.
Kevin
Kevin
