Need help on placement of hyro cylinder
buckmtn
Stokesville,Va
I know that I am either going to mount the fixed end to the axle or my cover but how do you go about placing the other end to the tierod. I assume the axle needs to be under the truck with the rest of the steering hooked up. Do you turn it to full lock then fully extend the ram and tack the brackets to the tierod. Walk a newb through it please. I have searched but found nothing set in stone.. Thanks Stock tierod location
