The Pumpkinator
Well it turns out I need to get my
prioritized and focus on more critical drive train/suspension parts. Before I start getting carried away with longer leafs and shackles, moving the axles around, and playing with lift, etc etc etc, I need to focus on one BIG factor that has omnipotent authority over any suspension mods; the drive lines. I'm so nit picky about what the slightest tweaks will do to my drive line angles, I find myself
,constantly chasing all the loose ends so that the installation will go smoothly without the slightest problem!
I figure do it right the first time, I DD a 91 K5 with a 4" lift/shackle flip rear, I had to lower the T case an inch to cancel out my drive line vibes. So what would you guys recommend for double cardan drive lines? I plan on getting a SYE 'flange style' kit to go with the drive shaft. Who did you order yours from? What were the processes in getting the right parts? What other key factors do I need to consider? And as usual, what kind of financial $$$$ devastation should I expect?
I really think this is the correct way to go, after a conclusion is made I will drop the cash to get things done right so I can progress with my 'snails pace' build.
Thanks for your input in advance!
,constantly chasing all the loose ends so that the installation will go smoothly without the slightest problem!I figure do it right the first time, I DD a 91 K5 with a 4" lift/shackle flip rear, I had to lower the T case an inch to cancel out my drive line vibes. So what would you guys recommend for double cardan drive lines? I plan on getting a SYE 'flange style' kit to go with the drive shaft. Who did you order yours from? What were the processes in getting the right parts? What other key factors do I need to consider? And as usual, what kind of financial $$$$ devastation should I expect?
