Working on a 02 Chev 1500, been sitting in a feild for 5 years.
Got it in my shop and was trying to get it running.
First I made sure it turned over by hand. Hooked up a good battery to it but no start… rolled over a bit then locked up… turns over by hand… pulled first two plugs out of pass side engine, full of fuel!?
Pull the rest of the plugs, the remaining 6 are dry.
The engine hasn’t ran in years and I never really had it cranking very long.
What would make the cylinders fill with fuel like that?
Side note,
Fist I thought it was head gaskets. The liquid that came out didn’t smell like gas, probably because it’s 5 years old, and my nose is plugged.
Lit the puddle on the floor on fire to be sure. Yup gas. Ok next I turned the engine over without the plugs installed.
Proceeded the light the engine bay on the passenger side on fire! Ran to get my extinguisher! Got it out before any damage! Thank Fock I had one closeish to me! Dumbass!
I blew the rest of the gas out of the cylinders with air.
The plugs are all needing to be replaced and I pulled one plug wire apart getting it off the plug so it is just sitting there till I can figure out why the fuel was in the cylinders in the first place?
This is the truck, if I can get it running it will my new work truck.
Side note,
