jtrapani
I removed all my emissions junk and went all motor. My edelbrock carb has two ports in the front for vacuum lines. right now I have them blocked off but I need to know what they are in case I should be using them.
also, where can I trace the wire that hooks up to my electric choke??? Its apparently missing so I need to go to the starting point and maybe run a new wire.
Truck is an 85 k5 5.7. Had a quadrajet on it before.
thanks
thanks
