need help with hub removal
rezsst
West
Just cant seem to figure this out. Need to disassemble for knuckle. What am I missing.
There is a large snap ring that runs inside the hub that keeps the hub body from coming out. Get a scribe or a small screwdriver in there. You'll feel it.
After you get it out the hub body will come out. Behind that are the spindle nuts you will need a special 4 prong socket for.
Before you put the snap ring back in, put a slight bend in either end so it's easy to get out with something like a screwdriver.
Thanks I did this a year ago and I already forgot
