Need help with Jeep cherokee steering knuckle & brakes
rookie7
Registered Member
Georgia
Got a problem!
I ran into a problem when replacing the front brake pads on my 1999 Jeep Cherokee Classic. There are 2 bolts that hold the brake caliper to the steering knuckle. The threads inside the steering knuckle for the bottom hole and bolt are completely gone. How they got this way I do not know. I have had the Jeep since september, so this is the first time I have done a brake job on the jeep.
I have tried to re-tap the hole with no luck. The threads are too far gone and the hole is worn quite a bit.
Without replacing the steering knuckle what else can I do? A larger bolt doesn't seem to be an option since the bolt has to go through a bushing in the caliper. The bolt size is 5/16 or 8mm.
JB weld it for now? and replace knuckle later?
thanks for the help
And IIRC, I think it is a 9mm not sure the pitch though, I've done a bunch of those before.
x2 on the helicoil have done a couple myself
Be very careful about your bolt length its easy to get the bolt tight and have it just touch the rotor.
is it a bolt/slide if so ask the part counter for a ford escort repair bolt/slide. thay work. i use them all the time.
if its a bolt threw the slide tube then swap to american or metric size bigger and drill the slide out a bit to make the hole bigger and then tap the knuckle to that size.
i have done both before with good luck.
