Need help with part number SOLVED
FinnDRZ
Finland
UPDATED, LOOK AT THE LAST POST...
Can someone tell me, is the carrier model 3 or 4, if the ring gear is marked: 3819037 9 37 GM 11-72 2
Assuming it's for your 12b
Then, 9 37 are the teeth countings. So that gives you a 4.11 ratio. I think you have to go with carrier 4 (3.90 & up).
Walter
The carrier has number: 326662N GM 77 , is it series 3 or 4?
Can't find anything with that part number...
Nobody knows?
The problem is: I have a 12b with (broken) LS carrier series 4. I'd like to install LockRight, but the carrier is wrong (LS).
Now I'm able to have another carrier , part number 326662N . Is this series 3 or 4, and if it is 4, will it fit?
Please help...
Call the locker company and have them help you out. Randy's R&P might could help you too.
Better if they have email ... calling the US from Finland is expensive and means he has to be up in the middle of the night :D
-- A
