need more help...
xsmokey11499x
lake elsinore California.
okay so.. my tranny went out on me a week or two ago.. I got a new tranny in... I start er up... and it sounds like I got a FKN knock!!!
I thought maybe it was the tranny knocking. because it didnt have enough tranny fluid.. I filled it up. checked engine oil.. both good.
I get under the truck. and I do NOT hear any type of knock. ping anything.. but I hear it up top... sounds like the rear of the block.
there is no shavings on my oil dipstick at all..
I drove it 7 miles.. didnt seem like it had a loss of power..
checked oil again.. after driving.. and no shavings.. but the "knock" is still there
well.. I drained some oil.. stuck some lucas in there.. It quieted down alot.. can barely hear it .. But it is def. not a rod/bearing knock..
I think it was a stuck lifter or something.. maybe from not running for a while..
Make sure you got your torque converter bolts tight. I had a weld break on a converter and it sounded like a rod coming through the block.
Of course if the Lucas made it quiet then it's something else. Could have been a stuck lifter
are you running the same converter as before the tranny swap? You could have a bad converter but as Big Pappa said check the bolts. I bolted in 700R4 converter and used the bolts from the old converter and they were about a 1/16 of an inch to long for the new converter so they did not tighten down all the way and the converter knocked bad. Replaced the bolts and all was well.
i'm using my old converter. same bolts etc. same everything, Just a different tranny case.
