The yoke on the 205 as I can see it on northerndrivetrain can only handle 30 degrees and I need 40.
Is there something I don't see?
Hmm. I think that means the material on the yoke would need to be clearenced a little bit because a 1480 ujoint can handle 38*. That may be worth calling them and seeing if there is enough material on the yoke to sand down/ remove some to get more angle without compromising the integrity of the yoke. If you cant get more angle out of it then it wont do you any good. Seems odd that its limited to 30*.
Another option would be to make your own yoke that bolts to the front flange of the 205. I had a for sale thread years ago where i sold all the parts to make a 1480 shaft using all d60 outer shaft ears and had a flange machined to fit the yoke, just needed to be welded. Ill see if i can dig it up to give you an idea. It would accommodate 38* easy (because yoke was meant for steering in front axle).
