I've been running my rig with only 1 rear shock (and it's blown
) for the last few months. I was just gonna re-weld my busted bracket and get new shocks, but I was thinking I might as well move the mounts to a safer location. what do you guys recommend? I was thinking of putting them on top of the axle tube and getting shorter shocks. any ideas? pics? I'd like to keep the upper mounting location where it is on the frame. will I run into any adverse affects with them on top - should they be staggered like the stock ones were - 1 on the front of the tube, the other on the back? should I move them in or out a little, or keep them on the same line as the originals? it's a 14BFF under my 81 K5
) for the last few months. I was just gonna re-weld my busted bracket and get new shocks, but I was thinking I might as well move the mounts to a safer location. what do you guys recommend? I was thinking of putting them on top of the axle tube and getting shorter shocks. any ideas? pics? I'd like to keep the upper mounting location where it is on the frame. will I run into any adverse affects with them on top - should they be staggered like the stock ones were - 1 on the front of the tube, the other on the back? should I move them in or out a little, or keep them on the same line as the originals? it's a 14BFF under my 81 K5Thanks
