herkdriver007
Issue is that she likes to stay in 1st gear unless i throw into neutral and give it some throttle, then shift back into gear it will likely upshift then.
i pulled the governor, it appears to be fine, and adjusted the tv cable to where about 1/2" of sleeve is showing past the bracket. seemed to help a bit, but it will still stick on occasion.
Trans is from somewhere around '89 (numbers are really worn down near the pan so hard to say). Lockup is wired to a switch in the dash.
So, do I need to pull the valve body next in my troubleshooting efforts? What say the CK5 experts?? No, no manual swap lol.
