Need some bolt sizes...
reddog64
Federal Way, Washington
So the K5 I bought came from a girl who's boyfriend decided to be an asshat and dissasemble random parts on this K5...
Well a few bolts are missing or have been replaced with whatever fit...
Need to know what and iff there correct...
1 - Bolts that grom from the trans bellhousing to the motor block... there's 6 of them. the two on the top seemed a different size (length) than the other 4 (2 on either side). How much length should go into the block? meaning after the bolt goes through the trans bell housing how much goes into the block? Do these have lock washers?
2 - trans inspection cover was missing... Got a new one, and the braces... but ALL the bolts are missing...
I know there was more but i cant think of them right now...
Engine to trans should be a 3/8" bolt about 1.5" long without any lock washers.
The inspection cover should also be a 3/8" bolt (assuming it's a K case using 6 bolts) and they too should be about 1.5" long. No washer on these either.
